58 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Printing Difficulties
11 Posts No Rating |
When I print the first floor plan of my project, an error note appears. It says, "An error has occurred while drawing the contents of this window. The window will be closed."
The drawing does print, but there are certain elements that do not appear. The section markers and text do not show. Though they are turned on in the View Properties, Visibility. I think that it may be a problem with the worksets.
Does this happen everytime?
If i experience this a restart of revit usually does the trick...
A restart did not work. This has happened every time I print a floor plan. I have not had problems with sections and elevations.
Try it on another system to see if it weild's the same results. If so, i suggest sending to support.
Printing Problems Revit 2012 |
Wed, May 16, 2012 at 7:31:01 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ] |
Sat, Jan 26, 2019 at 12:16:15 AM
17
Printing Query |
Wed, May 23, 2012 at 7:54:08 AM
Printing |
Thu, Jun 14, 2018 at 12:59:04 AM
some keynotes not printing |
Thu, Sep 15, 2016 at 4:43:39 PM
Members: | 2017250 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
