Forums >> Revit Building >> Technical Support >> Rotatable North Arrow
3 Posts No Rating |
Hello all. I am a relative newbie to Revit although I am a big fan. We are attempting to migrate to Revit 2009 from AutoCAD Arch Desktop 2008 and I am working on setting up templates and such. One of my problems is arising as I try to create a North arrow for our Sheets that can be rotated to match North. It is similar to the simple North arrow uploaded here but has "north" in lower case letters just below the arrow. Is there a way to make the arrow rotate while keeping the text upright? Thanks in advance for the help, Mike
Sure ... I did not make this family but use it to give you ideas.
Did you check the HELP menu???
3 Posts No Rating |
Thanks WWHub I will look into that. I appreciate the help. Typhoon, thanks for your assist as well but I think you misunderstood my question. I am looking for a north arrow family that I can orient at different angles on my sheets depending on which direction is north for my plan, not at how to rotate the plan and create true north with the building plan.
Sorry for that...
Process is: - Create the symbol of what you want the north pointer to look like. Draw is so it is centred on the two reference planes with North pointed vertical. Save and close.
- Create a new symbol and nest this north pointer into this family placing it centred on the two reference planes.
- Rotate it clockwise about 30 degrees.
- Add a dimension from the vertical reference plane to the 30 Degree North Pointer. And add an angle parameter.
- If you like load it into your titleblock and link the North Pointer angle to a new parameter in the titleblock. I use a type parameter because generally the north direction is the same on most of my sheets.
Done. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
3 Posts No Rating |
Thanks guys. That did it. I got one created that works just as I want it to. Thanks again!
ROTATABLE NORTH ARROW BUT NOT TEXT |
Sun, Jun 3, 2018 at 8:30:20 AM
North Arrow |
Tue, Jan 16, 2007 at 9:24:45 PM
North Arrow |
Fri, May 6, 2016 at 7:09:48 AM
Trying to create a Plan Title with a rotating north arrow |
Wed, Oct 13, 2010 at 9:51:09 AM
North Arrow for v.2011 |
Fri, Dec 9, 2011 at 7:05:58 AM
Members: | 2115320 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
