Forums >> Revit Building >> Technical Support >> Door Family/Glass Issue
Mon, Dec 29, 2008 at 10:16:07 AM | Door Family/Glass Issue
dkclayton
Hello Everyone,
 My issue is that I need to have a door family that has variable door swings/glass locations. I need the glass to move from one side of the mullion to the other. I have attached an image and I was hoping that someone could help me with this. If you don't understand what I'm asking please reply and I will try and word things differently.
 Thanks,
Mon, Dec 29, 2008 at 10:24:43 AM | Door Family/Glass Issue
4 Stars: 203 Votes
You must create Ref. planes with dimensions and add labels (parameters) and attach the element to those Ref. planes, so when you flex the family the glass also increase....
Mon, Dec 29, 2008 at 10:29:24 AM | Door Family/Glass Issue
You could set this up with glass built on both sides then control the visibility of the glass extrusions using a yes/no parameter.
Mon, Dec 29, 2008 at 10:58:37 AM | Door Family/Glass Issue
dkclayton
Thanks a bunch. The yes/no parameter worked wonderfully!
OOTB DOuble Glass 1 door issue
Tue, Sep 23, 2008 at 3:56:09 PM
Frameless shower glass door
Fri, Jul 9, 2010 at 11:50:11 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:36 AM
Overhead Door Family
Mon, Oct 8, 2012 at 9:38:20 AM
Glass behaving oddly
Thu, Nov 27, 2014 at 11:05:47 PM
Page generation time: 2.0445
