86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> flat roofs - best practices
Tue, Dec 23, 2008 at 11:30:49 AM | flat roofs - best practices
NancyHKA
Hello all,
This is my second revit project, so in our office we're still experimenting...I was wondering what y'all choose to do for flat roofs that have a minimal slope, like to an internal roof drain.  As far as I see it, there are two ways of doing this: use the tools in revit (I'm in 2009) to actually model the ridges and valleys in the flat roof, or just forget about the modeling and draw in the slopes in the roof as detail lines only in the roof plan.  Which method are people choosing to use?  What are your thoughts about the advantages and disadvantages of each one?
Tue, Dec 23, 2008 at 11:49:02 AM | flat roofs - best practices
3.5 Stars: 395 Votes
In our office, we model to the maximum roof thickness and  just use the 2D linework on the roof plan.  You really don't need to see the slope in overall sections and it will not show in wall sections.
Mon, Jan 5, 2009 at 10:55:24 AM | flat roofs - best practices
NancyHKA
Thanks for your input.  I just spent a lot of time using the new flat roof tools to model slopes in our flat roofs, and I was wondering if it was really worth it to go to all the trouble.  Is there a way to keep the 2D linework from getting messed up if the outline of the roof changes?  (Say, like, one edge moves a few feet.)  Do you try to lock the linework to the edges of the roof, or do you just end up re-drawing it when a change is made?
Mon, Jan 5, 2009 at 11:10:29 AM | flat roofs - best practices
I guess I have just fixed the linework .... but you could lock it in some instances....
Revit 2008 Multiple Roofs on Same level?
Tue, Jul 24, 2007 at 9:05:38 AM
12
Flat Roofs
Wed, May 28, 2008 at 5:24:52 AM
Vallys in flat roofs?
Wed, Aug 2, 2006 at 2:37:27 PM
flat roofs
Mon, Mar 7, 2005 at 8:38:24 AM
Flat roof - best practices
Mon, Mar 24, 2008 at 1:03:58 PM
Page generation time: 0.3304
