47 Users Online (45 Members):
Forums >> Community >> The Studio >> FBX or DWG
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
After a little experience with exporting my Revit models I havn't decided which is better to import into 3DS Max, FBX or DWG. I can see why FBX would be benificial in that many of the settings you apply in Revit open in Max as well, including materials, lighting data, geographic data and more. But suppose I'm just trying to pump out a large rendering that best describes my project. In order to create such a large image I have to use 3DS Max, Revit cannot handle the size nor was it ever meant to. SO, I've found FBX files brought into Max create huge files. Materials can be added again as well as anything else lost from importing the DWG. I wouldn't mind applying this lost data into Max if rendering time is reduced. Here's my main question: Is there a best practice to import a Revit model into 3DS Max in order to reduce rendering time?
Revit FBX causes 3DS Max to crash |
Wed, Aug 10, 2016 at 6:02:27 PM
Revit 2009 to FBX Import into MAX 9? |
Wed, Jan 21, 2009 at 1:12:22 PM
Revit to 3d Max FBX [ 1 2 ] |
Wed, Dec 1, 2010 at 8:52:13 PM
17
DWG export settings for curtain Panels for Max. |
Mon, Dec 1, 2008 at 6:42:35 AM
Exporting FBX file from Revit to 3Ds Max |
Wed, Sep 30, 2020 at 1:36:49 PM
Members: | 2016873 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
