55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Filled Regions on an elevation
Wed, May 25, 2005 at 12:17:01 PM | Filled Regions on an elevation
Glossy
Hi. The exterior of the building is modeled and I have elevations all around it. I decided to use a "Callout" at the entry. To show different colors of concrete panels I am using filled regions with patterns....but I would like to use 20%gray fills. Unfortunately I cannot get the filled region to print at a 20% transparent gray. Is there a way to do this? Need help for a client meeting. thanks Cipriano
Wed, May 25, 2005 at 1:35:38 PM | RE: Filled Regions on an elevation
TomDorner
4.5 Stars: 25 Votes
Does your filled region have a transparent background? You may also want to take a look at using Design Options to show different materials. HTH Tom
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families
Sun, Mar 8, 2009 at 7:10:29 PM
Revit 2014 Filled Regions
Fri, Jun 27, 2014 at 4:47:56 PM
11
filled regions...
Sat, Jun 13, 2009 at 4:48:38 PM
Page generation time: 1.1243
