Forums >> Revit Building >> Technical Support >> Nested parametric profile in fascia
Mon, Dec 22, 2008 at 5:40:34 AM | Nested parametric profile in fascia
nirim
5 Stars: 12 Votes
Hi there
Maybe it is me but as much as I try, including searching revit city forum
I can’t figure it out: I am creating profile for ridge tile with parameter to control the angle of the tile to insert it in deferent roof slops but when load the profile to the project and make now fascia family I can’t make the parameter that control the profile angle to work and I can’t find how to tell the fascia family to use the parameter that belong to the profile.
nirim
Mon, Dec 22, 2008 at 6:03:08 AM | Nested parametric profile in fascia
4 Stars: 201 Votes
Hi, in the properties you have the option "Angle" like you can see in the image attached....
Mon, Dec 22, 2008 at 8:52:11 AM | Nested parametric profile in fascia
nirim
5 Stars: 12 Votes
Thanks for the reply
But it isn’t that angle that I want to be able to change (see attached file)
The angle is in the profile family.
nirim
Mon, Dec 22, 2008 at 9:10:08 AM | Nested parametric profile in fascia
4 Stars: 201 Votes
Yeah, you must go to the properties, go to the "Project Browser" Profiles-choose your profile, right button and Properties, there you have your "Ridge Angle" like you can see in the image attached...
Mon, Dec 22, 2008 at 9:12:12 AM | Nested parametric profile in fascia
tim123
4 Stars: 19 Votes
Go to the Element Properties and change the profile there.  You will have the different angles that you have set in the family available.
Mon, Dec 22, 2008 at 10:32:25 AM | Nested parametric profile in fascia
nirim
5 Stars: 12 Votes
Thanks
I is seems to do the trick, although I though to skip the stage of going to the profile for changing  the angle and do it directly from the fascia family.
nirim
Mon, Dec 22, 2008 at 11:24:00 AM | Nested parametric profile in fascia
4 Stars: 201 Votes
The family it works fine, you don't need to "Trick"....
Yet another fascia profile question/profile
Thu, Apr 3, 2008 at 11:08:56 AM
Voids with gutter profile
Sun, Aug 21, 2005 at 10:00:21 PM
Nested detail components
Mon, Aug 8, 2005 at 6:45:27 AM
Custom barge board/ fascia end profile
Mon, Oct 15, 2012 at 3:14:42 PM
12
Fascia profile woes....it's only been 2 hours
Mon, Jan 4, 2010 at 1:16:20 PM
Page generation time: 0.5306
