98 Users Online (97 Members):
Forums >> Revit Systems >> Technical Support >> Revit 2009 Out of memory
2 Posts No Rating |
I just got an error "out of memory". I have been having trouble with my file for about 1 week. Have cleaned up whatever I can. Removed unneeded dwg files, purged, saved, created new central file, ect. Now this message. The program is running very slow. I even changed to a better computer. 2.40GHz 3GB Ram Windows XP 2002 Any thoughts? Thanks
Hi, I had some kind of problems like that in the past, i have a Dual-core 2.40Ghz with 8Gb Ram, ATI graphic card 512Mb, use Vista 64Bits and i install Web Updates (1,2 and 3) for Revit 2009, now i work fine, no more issues, did you upgrade your Revit??? What is the size of your file??? Did you create lots of "Create-in-place" in the project???
2 Posts No Rating |
Thanks, I will try the updates. Will see if that works.
1 Posts No Rating |
I 'm working on a project that have 40 mega byte volume, how can i improve my system's speed. i have hp 4540s with 4Gb ram , corei5 2.6.
thanks.
Are you using 2009? If not, then why did you tag onto this post instead of starting your own.
Look back through the posts and read about the 3GB switch. We had to set that on our 4GB systems.
2009 memory requirements |
Thu, Jul 10, 2008 at 4:08:14 PM
Revit 2009 Memory Issue? [ 1 2 ] |
Sun, Oct 12, 2008 at 9:54:16 PM
16
I have enough memory but Revit doesn't agree about that |
Sun, May 10, 2015 at 10:59:23 PM
Memory Hog |
Fri, Jul 27, 2007 at 3:58:49 AM
Out of Memory |
Mon, Apr 29, 2019 at 4:10:05 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
