71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Parameter Data - What's the difference between Constraints & Dimensions.
83 Posts No Rating |
HiI can find no explanation of the differences between these (in fact, all) options.One small difference I've noticed is Constraints don't grey out when a formula is added.But Other than that, I'm lost.Is there's a web page that I've missed that gives a description? Cheers Dave F.
Can you describe your problem in a bit more detail - what are you trying to do. Dimensions can be constrained.
Hi Thanks for the reply. I'm not trying to do anything specific, just trying to learn about when & where I would want to 'Group ParamterUnder' Dimensions, Constraints or Other etc. I can find specifc example telling me which I should use, but only for that example & they give no reasons why. I'm trying to find generic explanations of the usage. Cheers Dave F.
Dave If you are creating a family, it determines the location of the parameter in the Element property dialog box. It does not really affect anything else - if I'm understanding your query correctly.
A constraint can be a dimension if it is locked ... another constrait might be an alignment with a lock.
Room Tag & Room Dimensions |
Mon, Mar 13, 2006 at 3:11:05 PM
Family Instant Parameter Constraints Offset |
Fri, Feb 1, 2013 at 2:41:00 PM
Change Change Parameter "Group Under" Category |
Tue, Jun 21, 2016 at 2:04:10 PM
Parametric elliptical shape in family |
Fri, Feb 20, 2015 at 4:30:19 AM
How to make a flexible radius parameter for pipe thicknesses? |
Wed, Feb 8, 2012 at 12:55:42 AM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
