83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> LAYER PULLDOWN
Thu, Dec 18, 2008 at 5:59:10 PM | LAYER PULLDOWN
Manny
3.5 Stars: 6 Votes
WHAT I'M TRYING TO DO IS PULL THE DRYWALL LAYER DOWN LIKE THE STUCCO BUT IT DOES NOT LET ME
JUST ONE LAYER.  IS THAT CORRECT OR I'M JUST DOING SOMETHING WRONG? CAN ANYONE HELP PLEASE
Thu, Dec 18, 2008 at 6:38:38 PM | LAYER PULLDOWN
Manny
3.5 Stars: 6 Votes
SORRY HERE IS THE IMAGE TO SEE BETTER
Thu, Dec 18, 2008 at 6:46:12 PM | LAYER PULLDOWN
Manny
3.5 Stars: 6 Votes
Fri, Dec 19, 2008 at 1:23:15 AM | LAYER PULLDOWN
TJKENNEDY
3 Stars: 2 Votes
Is the drywall layer unlocked?
Fri, Dec 19, 2008 at 1:42:34 PM | LAYER PULLDOWN
manny - edit the wall family
  • turn on the preview
  • change it to section
  •  click on modify vertical structure / modify
  • click on the bottom line of the layer you want to move up or down
  • unlock it
Now, from a section, you can pull this skin up or down while the rest of the wall stays in place
Fri, Dec 19, 2008 at 3:15:33 PM | LAYER PULLDOWN
Manny
3.5 Stars: 6 Votes
I DID IT BUT ALREADY BUT WHAT I WANT IS BOTH LAYERS TO PULL STUCCO AND DRYWALL, WHEN I UNLOCK BOTH LAYERS AN ERROR POPS UP. AS YOU CAN SEE IN THE IMAGE PREVIOUSLY SHOWN.
Mon, Dec 22, 2008 at 8:39:55 AM | LAYER PULLDOWN
Sorry - can't help you - N o error message shows in the image you posted ....
Mon, Feb 13, 2012 at 11:59:26 AM | LAYER PULLDOWN
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I've unlocked the wall layers using the modify vertical structure. However, I dont get any grips when in section to move the layers I just unlocked. I've tried unlocking and relocking layers to appease it but then I get an error saying that I can't go beyond extension layer. What gives? Does it have to be a certain kind of layer ( finish 4 or 5)? Does it have anything to do with wrapping?
I have another wall with virtually identical settings and it works fine. Revit just doesnt like this new wall I made for some reason.
 Thanks.
Tue, Feb 14, 2012 at 9:50:55 AM | LAYER PULLDOWN
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I discovered that the layer pulldown doesn't work in the following instances:
If geometry is joined together then the vertical sections do not function.
Also, unlocked layers must be adjacent so it doesnt let you do both outer layers(?)
Tue, Feb 14, 2012 at 10:05:55 AM | LAYER PULLDOWN
Be creative!!!
As long as both outer layers will go to the vertical elevation, you can do both layers.  Just unlock all of the interior layers, set the wall to where you want THE OUSIDE LAYERS and then move all the inside layers away from that.
Tue, Feb 14, 2012 at 3:16:22 PM | LAYER PULLDOWN
#11
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Or rather parametric.
Good suggestion as always WWhub. Thanks.
Exporting and layer modifiers
Wed, Nov 16, 2011 at 4:04:33 PM
How to control a single-layer wall?
Wed, Apr 28, 2010 at 2:39:50 AM
Joist on demo layer
Thu, Aug 2, 2012 at 3:41:02 PM
Layer Exports Colors
Sun, Feb 1, 2009 at 1:49:31 PM
Sketchup to Revit - Layer/Material Problems [ 1 2 ]
Thu, Jun 10, 2010 at 11:04:46 AM
21
Page generation time: 0.6054
