51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Linked revit model keeps unloading.
83 Posts No Rating |
Hi When I save to central, every few times, a warnng message telling me it can't find the linked model & will unload. I think the problem maybe that the Saved Path is still the consultants server path & not mine. The local alias point to my server. If this is the problem, how can I changed the saved path. If not, how do I fix this annoyance? Cheers Dave F.
You should be able to change the path from the Manage Links dialog box (under File menu).
Ah Yes, I see. i give that a go. Also, this seems similar to my problem. http://www.revitcity.com/forums.php?action=viewthread&thread_id=10500 I'll give them a test. Thanks for your reply.
What's the difference between Unloading a Linked Revit File and Removing? [ 1 2 ] |
Mon, Feb 27, 2017 at 1:57:44 PM
16
Room Finish Schedule - Linked |
Wed, Feb 17, 2021 at 3:52:40 PM
Visibility Graphics settings: saving them when unloading a linked model |
Fri, Feb 25, 2011 at 1:54:00 PM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
Not able to place room copied from linked model |
Wed, Mar 18, 2015 at 8:10:37 AM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
