76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> Splitting an elevation view
1 Posts No Rating |
I hope I make sense with this question. We want to split our elevation in 2 parts and move the on closer into the buiding than the other to please our architects in the office :/
Do you think this is possible? I haven't had much luck with it but will keep on trying.
Thanks guys.
You could simply have two elevation views or you could do a callout from the main elevation.
HTH
Tom
Easy.
Turn on the crop region in the elevation.
Select the crop region then hit one of the split lines to break the elevation into two parts. (4 quiggly lines around the border of the crop region.)
Then adjust each crop to the area you want to see. Then select one crop region and you'll notice there is now an arrow in the centre. Drag this to drag each section closer together...
HTH.
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Splitting a wall in 3 EQ sized walls |
Tue, Feb 5, 2008 at 11:51:51 AM
Making view titles reference each elevation |
Mon, Oct 21, 2013 at 7:30:20 AM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW |
Mon, Jul 29, 2013 at 4:50:17 PM
Splitting a wall with a Reveal |
Fri, Feb 19, 2010 at 11:25:44 AM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
