41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Floor hosted family to not be hosted by floor
Tue, Dec 16, 2008 at 2:18:52 PM | Floor hosted family to not be hosted by floor
tinninttu
I have this shelving unit that was created by someone in the office as a floor hosted model. If there any way that i could change it to not be hosted by the floor, or anything. Is there anyway to change its category to a generic model or even just a furniture model instead of a generic model floor hosted?
Thank you for your help
Stephanie
Tue, Dec 16, 2008 at 2:38:16 PM | Floor hosted family to not be hosted by floor
4 Stars: 204 Votes
Try to "EDIT" the family, go to "Settings-Family Category and Parameters" and change the category...
Tue, Dec 16, 2008 at 2:46:57 PM | Floor hosted family to not be hosted by floor
tinninttu
Thank you.
But how do you change what it is hosted by? In the properties it has "hosted by:......" grayed out to where i cant change it.
Thanks
Stephanie
Tue, Dec 16, 2008 at 3:05:21 PM | Floor hosted family to not be hosted by floor
4 Stars: 204 Votes
And in project when you pick in the object, in the "Options Bar" you don't have "Pick Host"??
Can you put the model here to upload???
Thu, Dec 18, 2008 at 11:08:01 AM | Floor hosted family to not be hosted by floor
tinninttu
When the shelves are loaded into a project and then you click on the properties of the element under constraints "Host" is grayed. I even loaded into a new family template but it is till being hosted by the floor. I attached the file. Try and load it into a generic project to see what my problem is. Thank you for spending time on this and for helping me out.
Stephanie
Thu, Dec 18, 2008 at 11:46:44 AM | Floor hosted family to not be hosted by floor
3.5 Stars: 401 Votes
You need to rebuild the family in a non-hosted template.  You should be able to open them side by side and copy paste.
BTW - don't you have a floor???  If the problem is how high off the floor, that is an easier answer.
Tue, Dec 23, 2008 at 5:48:51 PM | Floor hosted family to not be hosted by floor
tinninttu
I have tried to copy/paste but you are not able to between families. It wouldn't let me. i could load it into another family template but it was still hosted by the floor. And yes i have a floor but the shelving unit is very versatile and we want it to be upper shelving sometimes. I added an offset height to bring it up off the floor, but it kept moving the bottom reference plane down instead of moving the unit up. I aligned, locked, etc....... til i got a headache Smile But it still kept moving the ref plane instead of the shelving. Thanks for your help. Please let me know if you have any other suggestions
Thanks, Stephanie
Tue, Dec 23, 2008 at 6:47:16 PM | Floor hosted family to not be hosted by floor
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Stephanie,
It kinda sounds like you are having a few problems if I understand correctly.
I tried your file and it was not a floor based family, I could place where ever I wanted.
It does however, become hosted by the floor once it is placed on a floor, which is the correct behavior.
When placed out in space it should be hosted to a level. If it wasn't hosted by some kind of work plane it would n't allow you to place the family at all. In other words Revit will only place objects on a defined workplane.
If you are looking to rehost the shelf after it's been placed then you can pick the shelf and select the
PICK HOST option from the options bar and simply selct a new level to place it at.
If you want to be able to adjust an offset parameter to raise it off the floor you will need to add (or fix) a parameter.
When I opend the family I didn't see a parameter driving the placement height so I was not able to chage it. What I did was just simply select everything in the FRONT elevation EXCEPT THE REF. LEVEL and just moved it up "x" distance.
Then I drew a Ref. Plane above the Ref. Level and dimensioned from the Ref. Level to the Ref. Plane and applied a lable called Shelf Placement Height.
Then I went into the sketch for the boarder of the shelf and aligned/locked the bottom line of the border to the new ref. Plane.
After that I flexed it and loaded it into the project and it worked no problem.
HTH
-Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Floor hosted family?!
Wed, Jul 2, 2008 at 5:56:49 PM
Floor with Valleys and Ridges - Hosted Components Won't Slope
Thu, Oct 28, 2010 at 2:01:36 PM
Floor Hosted Families on a Sloped Floor
Wed, Jun 4, 2008 at 7:31:21 AM
FLOOR / CEILING PROB WITH HOSTING LIGHT FITTINGS
Thu, Dec 15, 2005 at 10:30:38 PM
Revit 2011 - show ceiling-hosted objects on floor plan?
Tue, May 3, 2011 at 5:47:48 PM
Page generation time: 1.3211
