129 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Importing AutoCAD topo 3D lines
Wed, May 25, 2005 at 3:20:15 AM | Importing AutoCAD topo 3D lines
phindes
I have a site survey with contour lines shown in 3D at the correct heights. I import this into revit to use as the basis for generating topo planes, which works fine. However, when I import the 3D CAD file to match both files ORIGIN, I find the imported 3D contours are no longer at the correct height. I have to work out at what Z value the imported dwg file is imported at, and then adjust this in the properties. Any idea of how to get an autocad 3d file to align the z axis at 0? Thanks!
Wed, May 25, 2005 at 3:33:45 AM | RE: Importing AutoCAD topo 3D lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When importing an AutoCAD file you have the choice to set which level you wish to import the file into. Make sure the level your importing into is 0. HTH.
Wiggly Lines when importing Topo into Revit
Tue, Jun 28, 2016 at 9:46:20 AM
Importing / Modifying Topo from AutoCAD
Thu, Feb 16, 2012 at 11:14:11 AM
Importing Topo
Wed, Jan 9, 2008 at 2:51:40 PM
Importing AutoCAD Topo - Import Symbol Issue
Thu, May 3, 2007 at 12:49:36 PM
Fri, Feb 2, 2007 at 12:28:15 PM
Page generation time: 25.0409
