53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to create Folded Plate Staircase
Tue, Dec 16, 2008 at 8:15:35 AM | How to create Folded Plate Staircase
ashit
I need to create a folded plate staircase with the following dimensions in Revit Architecture 2008.
Riser = 7", Tread = 11". Tread & Riser thickness 7". No Stringer beam. Please look at the attached files to see what I'm wanting to do.
I am able to create a monolithic stair case of this type but the Tread & Riser thickness needs to be less than 7".
Tue, Dec 16, 2008 at 8:27:36 AM | How to create Folded Plate Staircase
Look at the stair samples in the on-line area: http://revit.autodesk.com/library/archive2008/html/index.html
Wed, Dec 17, 2008 at 12:28:12 PM | How to create Folded Plate Staircase
ashit
Thank yu for your response. I looked at the staircase samples. None of the samples is a folded plate the way I have described.
Wed, Dec 17, 2008 at 1:02:35 PM | How to create Folded Plate Staircase
Sorry but you are wrong!  I see exactly what you want.
In 3d - look the first stair called "residential spiral" -  the straight run. Goto the properties of that stairs and in its type description, change the tread thickness to 7"... see!
Wed, Dec 17, 2008 at 1:50:31 PM | How to create Folded Plate Staircase
ashit
No it is not the same as my sample. I have been able to do this any eays. The tread just stops below the outer line of riser. I want the tread to go full depth/ thickness of the riser(7" thick Riser) as shown in my example.
Wed, Dec 17, 2008 at 4:01:20 PM | How to create Folded Plate Staircase
You have to be creative.  Add a nosing to your tread that does this see attached
Wed, Dec 17, 2008 at 4:05:15 PM | How to create Folded Plate Staircase
jarosa
jarosa Avatar
4 Stars: 5 Votes
check out the attached file. I think you can get there. mess with the stair properties. I set the stair wwhub referenced to 7" tread 7" riser. It's a start. i'm not sure there is an easy way to clean up the lines except for invisible lines.
John
Wed, Dec 17, 2008 at 4:10:00 PM | How to create Folded Plate Staircase
jarosa
jarosa Avatar
4 Stars: 5 Votes
I defer to wwhub. He has it.
Creating Folded steel plate stair with concrete tread
Wed, Sep 5, 2012 at 1:07:48 PM
Staircase help - winder staircase
Wed, Nov 28, 2007 at 4:31:49 PM
plate not saving
Fri, May 2, 2025 at 1:22:20 PM
Sill plate?
Thu, Jan 28, 2010 at 5:10:17 PM
Staircase not going to levels?
Mon, Mar 7, 2016 at 6:06:53 PM
Page generation time: 2.0860
