Forums >> Revit Structure >> Technical Support >> Window in wall w/ brick veneer
28 Posts No Rating |
sorry for posting this in the wrong place previously. I need a good tutorial or such for editing a window so that it hosts properly in a stud wall w/ a brick veneer at the walls base. Currently my window and trims react to the entire wall thickness despite the fact that it only cuts thru the stud portion of the stacked wall type
Stacked walls can create this type of problem. I would modify the family so that I had a setback variable from the wall face.
How?
You need to learn how to build families. There are tutorials in the links area here on RevitCity. Look under resources ... DGCad is a good place to start. You need to build the window family that is constrained to a reference plane. The location of this reference plane in relation to the wall face is a variable that you set when you place the window. This is a useful exercise that you will use many times. Start with building a simple extrusion/ window family ... learn how to control that, then you can add other elements.
BTW ... If you absolutly can't wait to learn how to do it right, then split your wall and only host your window in the thinner wall......
An architect I was working with had the same problem. What I did was open the window family and create a new reference plane parallel with the wall and named it "outside of window". I created a new instance length parameter called "Window Depth", and tied it to the inside face of the wall and the new reference plane. I then took all the geometry that was originally tied to the outside face of the wall, and tied it to the new reference plane. What this did was allow the family to cut through all the layers of the wall, but stop the window itself (frame, etc.) at a specified distance (Window Depth) from the inside face of the host wall. Essentially, you will be creating a replacement for the outside face of wall constraint. Unfortunately, I no longer have access to the family I made, and I don't have revit at the moment, so I can't recreate it. It shouldn't be to hard for another forum member here to throw together a rough window, or if that doesn't work I can install Revit (I've been meaning to anyway) and recreate it.Howeve, I would encourage you to try to figure out how to do it on your own.
I'd love to figure it out myself, but I'm new to revit and this is all Greek to me. I open a window family and all I see are lines I don't know how to manipulate. i guess I'm going to try and find a good family tutorial...
Yeah, it is a bit confusing at first, and this is quite a project if you have no experience. I currently have time, and I'm downloading Revit right now. If you want, send me an email (tjkennedy3891@yahoo.com) and I might be able to work something out with you.
brick veneer window insertion question |
Tue, Nov 23, 2004 at 4:28:49 PM
Window Placement in Stud/Brick Veneer Wall [ 1 2 ] |
Wed, Feb 4, 2009 at 11:22:19 AM
15
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008 |
Wed, Sep 3, 2008 at 12:33:09 AM
BRICK VENEER WALL |
Fri, Jul 22, 2005 at 8:55:04 AM
New Wall with Brick |
Tue, May 26, 2009 at 9:36:24 AM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
