137 Users Online (136 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> Can't attach circle void
Sat, Dec 13, 2008 at 10:56:28 AM | Can't attach circle void
DAVID85027
I am trying to create a universal baseplate for steel columns.  I have created a extrusion and voids to create a plate with holes.  I had locked all the diminsions to be instance type parameters so the length width and thickness is controled by the user.  Now I need the holes to be spaced accordingly and sized for anchorbolts.  BUT, I can not get the void circles to lock to any reference plane!
Now I am stuck because the holes will not move with any parameters and sets still where ever I placed them in the family editor.
Someone please help!  I am trying a new field in REVIT in which steel detailing can be accomplished.  This will not only improve my acuracy but also maybe a way to make some extra dough.
Thanks.
Sat, Dec 13, 2008 at 1:50:08 PM | Can't attach circle void
4 Stars: 203 Votes
Images of what are you trying to do was fine....
Sun, Dec 21, 2008 at 7:03:50 AM | Can't attach circle void
tim123
4 Stars: 19 Votes
Draw a reference planes and then create your void extrusion using the ref planes as a setout point for your void extrusion.  The holes should move with the ref planes.
Tue, Dec 23, 2008 at 11:00:16 AM | Can't attach circle void
DAVID85027
Thanks Tim!  I have just finished my little project and had uploaded it into the gallery.  It is called "column with base plate and cap plate" (how original). Check it out.
How tags attach to elements
Tue, Jul 22, 2008 at 11:20:13 AM
Attach wall based items to Void extrusion-Nested families
Wed, Aug 28, 2019 at 1:58:20 PM
Mass Geometry Flaw | Circle points
Fri, Dec 4, 2015 at 4:04:47 PM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:27 AM
Constraining a circle centered between two reference planes
Fri, Apr 7, 2017 at 8:22:51 AM
Page generation time: 1.2264
