Forums >> Revit Building >> Technical Support >> Attaching walls to the bottom of stairs
2 Posts No Rating |
When a staircase cuts through a wall, how do you lower the wall and attach it to the bottom of the stairs. Also how do you draw a wall so the underside of the stairs are not seen in the room?
If the wall is curved then refer to my tutorial.
If its just straight, you can't actually "attach". you can select the wall and choose to edit the profile in elevation to trace the underside of the stair.
HTH.
2 Posts No Rating |
Thank You
5 Posts No Rating |
still got a question , when you use the cut profile to "attach" a wall underneath the stairs and you need to create a room bounding , it does not recognize the lower face of the stair as the room boundry , at least i can't seem to do it , any tips please??
Use a room boundry line
5 Posts No Rating |
but thats for a plan view , but i'm building a model to use with thermobuild for thermal calculations and need the volume of the room , there for i need a top constraint and the down surface of the stair can't be read as a finishing surface, and i can't draw boundry lines on a section view (or can i ?)
Model a floor or ceiling under the stair. Then these can be room bounding elements and define the top of your room... Stairs are not room bounding elements unfortunately.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
5 Posts No Rating |
thanks , got the job done !!
1 Posts No Rating |
Mr Spot where's the tutorial for the curved wall? im having a hard time trying to find out how to attach a wall underneath a set of curved stairs.
Edited on: Wed, Aug 24, 2011 at 10:55:59 AM
Attaching walls to stairs |
Tue, Aug 22, 2017 at 12:20:11 AM
13
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:43 PM
attachig walls to circular stairs |
Wed, Feb 13, 2013 at 4:17:34 AM
Attaching Curved walls to underside of Curved Stairs |
Wed, Sep 12, 2012 at 12:43:48 PM
Attaching Railign to stairs... |
Sun, Jan 23, 2011 at 8:59:02 AM
Members: | 2102378 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
