94 Users Online (93 Members):
Forums >> Revit Building >> Technical Support >> model: column-"properties" dims not scaling to whats shown on drawing
160 Posts No Rating |
why would the attached column behave as it does? Model menu: column: wood timber column: inserted "5 x 5". depth and width from "type properties" indicates it should be 4-1/2" x 4-1/2". on sheet it measures 5-1/2" x 5-1/2" same with other columns inserted from same location
Open the family and check the parameters.
thanks, one other question; the "insertion point" was never aligned with a corner of the post. I haven't at this point figured out how to adjust the location of the insertion point. Can this also be done from the family editor?
I think I found it under defines origin? - On the Family Editor Design Bar, click Ref Plane.
- Sketch the reference plane.
- Click Modify and select the reference plane.
- Click .
- In the Element Properties dialog, select the check box for Defines Origin.
Specification column "Elevation at Bottom" |
Wed, Jan 28, 2009 at 7:43:12 AM
14
Can't read "Temp. Dims", too small?, change the size! |
Fri, Aug 17, 2012 at 5:19:26 AM
Ceiling Plan tags in Linked Model Views "Moving" (2010) |
Tue, Dec 21, 2010 at 7:20:58 AM
How to make a "Model in-place" a "Family" |
Thu, Mar 17, 2011 at 5:07:59 PM
plaster on column? "really in trouble".. |
Tue, Dec 18, 2007 at 9:07:39 AM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
