64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door Family Formulas
Fri, Dec 12, 2008 at 10:24:12 AM | Door Family Formulas
tinninttu
I have a door with full height sidelights on either side. This door was already built but i am wanting to modify it by adding our trim to it. The width parameter is set up to the actual door: 3'-0", while the sidelights have a separate width parameter of their own: 1'6". I am wanting the "Width" parameter to be overall: 6'0". I am wanting the formula to be something like this: Width + Sidelights*2. I have typed that exact formula in and get a warning saying "There is a circular chain of references among the formulas". I am not understanding what that means exactly. Please let me know how i should type the formula to get what i am wanting. Thanks Smile
Stephanie
Fri, Dec 12, 2008 at 12:54:14 PM | Door Family Formulas
tim123
4 Stars: 19 Votes
What are you calling the formula parameter?  The formula may be referring to itself.
Fri, Dec 12, 2008 at 2:24:04 PM | Door Family Formulas
ChopperDave
The circular chain just means that your Width parameter is controling some other parameter that is in turn controling the width parameter. Easy fix:
Leave the Width parameter set to your door width and change the width of your opening for the wall to be the Rough Width parameter. Then set the formula for the Rough Width to "Width + Sidelights * 2"
You will probably have to unlock the edges of your wall opening but this should work.
When you schedule this its going to show the width of the door not the width of the door and windows combined. If you want the windows to be added to the width you will need to make another parameter and set the door width to that.
Fri, Dec 12, 2008 at 2:32:47 PM | Door Family Formulas
tinninttu
awesome thanks a bunch, i'll try that
Fri, Dec 12, 2008 at 3:00:48 PM | Door Family Formulas
tinninttu
that worked! Thank you for your help Smile
Stephanie
HELP WITH FAMILY PARAMETERS AND FORMULAS!
Mon, Jan 2, 2012 at 2:11:06 PM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:06 PM
14
"can't find solutions for formulas" error
Wed, Aug 3, 2016 at 5:46:22 PM
to import shared parameters with formulas.
Fri, Jun 20, 2014 at 7:19:06 AM
Calculating two Formulas on the same row in a Schedule
Fri, Dec 17, 2010 at 7:22:57 AM
Page generation time: 0.8655
