87 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> import acad 3d objects and convert to Revit
Tue, May 24, 2005 at 12:23:51 PM | import acad 3d objects and convert to Revit
Mantisguy
Mantisguy Avatar
Is there anyway to convert a 3d base Autocad object to a Revit component other than using the import command?
Tue, May 24, 2005 at 8:48:47 PM | RE: import acad 3d objects and convert to Revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
depends what sort of base drawing we are talking about. The import command is the only way but it can be used in different ways. If its a building model already in autocad, you could import it in as a massing element, using create mass. then you can pick the faces of the import to apply walls, floors, roofs, curtain systems... HTH.
CONVERT RHINO TO REVIT
Thu, Feb 13, 2020 at 5:10:12 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:59 AM
ACAD Import Problems (With Blocks)
Mon, Jan 12, 2009 at 5:26:47 AM
Import 3D objects from VIZ to Revit
Wed, Jun 20, 2007 at 12:26:10 PM
ACAD Import
Wed, Apr 1, 2009 at 9:05:00 PM
Page generation time: 2.2498
