47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Specification Sheet (Notes)
Thu, Dec 11, 2008 at 4:46:50 PM | Specification Sheet (Notes)
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Hello, I am a fairly green REvit user and I am working on TRansfering our Office Standards from Auto Cad To Revit Structure 2009.
When We create a Spec Note Sheet we add the Note required for that Job. So each set of notes is a Block that we insert into a sheet. I Would like to do the same For Revit, and I tried doing each block of notes on a drafting View, then saving to library for use on any project. The problem is that when I insert into a sheet i can't Align the notes properly.
My question is, IS there a better way to do this? how do you guys deal with your notes sheets?
Any Suggestions would be greatly appreciated.
Vanrevit
Welcome to the REvitlution!!!
Thu, Dec 11, 2008 at 4:50:51 PM | Specification Sheet (Notes)
Search the forum for "sheet notes"
Fri, Dec 12, 2008 at 8:32:03 PM | Specification Sheet (Notes)
critter
Not many people refer to using legends. I think legends would be a fine way to organize sheet notes.
Sat, Dec 20, 2008 at 3:27:33 PM | Specification Sheet (Notes)
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Ok, I have done some research that will be very usefull. The Archies Don't Ahve this Option in Revit Architecture. IF you are a subscription member and yo uhave downloaded REvit Extensions, Unde the Miscellaneous Tab you will find the
"TEXT GENERATOR" Tool. This is the best tool to use for setting up you Notes Sheet.
I hope thi swas Helpfull for those of you that have struggled to deal with this issue. Cheers!
Vanrevit.
PD: I bought the MAstering Revit Structure 2009 book, and the content is fenomenal, I Highly Recomend it.
DETAIL GROUP: INCONSISTANCIES w-PLACEMENT of NOTES
Mon, Dec 8, 2008 at 8:37:37 AM
Create Sheet notes symbol to add to sheet plan
Tue, Apr 14, 2009 at 4:07:25 PM
Production Text Notes - Global Visibility
Wed, Mar 8, 2017 at 1:43:55 PM
sharing notes with other projects
Sat, Dec 29, 2007 at 3:25:56 PM
Sheet order in Project Browser
Tue, Sep 23, 2014 at 10:58:43 AM
Page generation time: 0.7656
