Forums >> Revit Structure >> Technical Support >> Footings and Piers
15 Posts No Rating |
I have a footing with a pier a blend, an extrusion and another extrusion denoting the grout, leveling plate and base plate.I had set the visibilty for the extrusions and blend to appear only in fine mode not in coarse. and it works in plan view with the footing by itself and next to a wall footing.if I cut a section thru these footings and put it in fine my isolated footing looks correct but the footing next to the wall footing "looses" my extrusions (grout, leveling plate & base palte).does it have to do with the line work or do i need to create additional parameters such as a "yes" "no" parameter.
Can you post a screenshot of what's happening, and possibly upload the family? That would go a long way toward sorting out the problem.
TJKENNEDY, Attached is a small file showing my problem. in the plan view it looks the way i want it to look. but if you look at the setcion the footing next to the wall footing is not showing my grout, leveling plate and plate, but the isolated footing is showing it and it is the same footing. Thanks for looking into this
I'm not seeing any attachments.
TJKENNEDY, Sorry about that!!!Edited on: Wed, Dec 17, 2008 at 12:00:40 PMEdited on: Thu, Dec 18, 2008 at 10:40:01 AM
Edited on: Thu, Dec 18, 2008 at 10:42:20 AM
Continuous footings for the Piers |
Mon, Sep 30, 2013 at 12:23:17 PM
Concrete pad footing moves with steel column |
Thu, Jan 6, 2011 at 4:27:33 PM
foundation piers |
Mon, Feb 18, 2008 at 5:36:12 PM
Brick Piers |
Fri, Jul 8, 2011 at 3:14:28 PM
How can I show concrete piles/piers beyond in a section view |
Tue, Sep 20, 2005 at 6:59:34 PM
Members: | 2100632 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
