71 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> dimension center lines in drafting view
10 Posts No Rating |
I am drawing a detail in a drafting view. is there a way to make my dimensions read my detail lines as center lines?
24 Posts No Rating |
has anyone got a solution to this. i really would like to be able to "force" a center line dimension
Why do you need to force this? In the properties of any arc, you can make the center mark visible. And if your center is out of view, you can drag the radius dim value and enpoint back into range.
There is only one way I know to do this, but it involves adding a family. You can create a detail component family which will have a center reference plane. If you use that instead of a <centerline>, the program will recognize it as a centerline. I made the family and it is attached. Let me know if this works for you.
Thanks lizard ... sounds like that should work. yet another round way to do what should be a simple thing ... jakub c
Lizard
This is good.
orthogonal dimensions to radial dimension center point |
Fri, May 14, 2010 at 3:22:32 PM
Dimensioning Drafting???? |
Thu, Feb 6, 2014 at 2:42:45 PM
Dimension center line of foundation |
Thu, Oct 4, 2007 at 7:40:43 AM
dimensioning to a center mark of an arc |
Wed, Jul 5, 2023 at 3:13:09 PM
Dimensioning tolerances to use align dimension with grid lines ? |
Tue, Feb 9, 2016 at 11:18:30 AM
Members: | 2030512 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
