Forums >> Revit Building >> Technical Support >> images when print have a diferent colors! why?
40 Posts No Rating |
images render when print have a diferent colors! why? do you know calibrate the printer? or use some other program? how you usualy you do after export a image? thnks a lot
This has been a problem for a long time ... do you calibrate your printer ... or your monitor - probably have to do both ... and to what standard. I don't believe there is any good solution yet.
There are methods to accurately calibrate printers and monitors - some examples are shown on this website, i'm sure that there are many others also.
Sorry - http://www.bodoni.co.uk/index.php?cPath=38_42&osCsid=faa86d67f9341bc1e327ca955ecc5bbb
i herd some where thats exist some programs to calibtate the monitor, but i dont have and know whao its work.. will try some print and arrive at one i like, thanks
Interesting and ... expensive for most users. Back in the '80's using DOS based AutoCAD, there were no solutions... Color printing was external, was trial and error and cost a lot. I used to set up a camera and take pictures of my screen to show the client.
Setting Line Colors to print in grayscale |
Wed, Feb 21, 2007 at 10:21:50 AM
Elevation colors |
Thu, Oct 19, 2006 at 2:34:32 AM
Colors and Printing |
Thu, Jul 19, 2012 at 10:11:32 AM
Imported Raster Images Not Printin |
Wed, Sep 23, 2009 at 3:39:10 PM
Printing image problems |
Wed, Jun 15, 2011 at 12:01:41 AM
Members: | 2115710 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
