56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Coffee Mug
Wed, Dec 10, 2008 at 3:08:49 AM | Coffee Mug
rossaftermath
5 Stars: 5 Votes
I created a coffee mug as generic model(to scale)... basically i just used a revolve to form the mug and a sweep for the handle.. however.. the mass that i created is dis-formed and edgy(if you look at the yellow mug in the render and in the family..)
Why is it doing this? is the scale to small?
Wed, Dec 10, 2008 at 7:15:10 AM | Coffee Mug
4 Stars: 203 Votes
Revit have problems (yet) to deal with small curved elements....
Wed, Dec 10, 2008 at 7:32:08 AM | Coffee Mug
tim123
4 Stars: 19 Votes
Revit facets small round objects, but it does depend on how they are created - see attched image.  The cylinder on the right was extruded and the one on the left was revolved.  Both have a 50mm diameter.
Wed, Dec 10, 2008 at 7:41:34 AM | Coffee Mug
4 Stars: 203 Votes
Yeah, with 2mm on the right is Revolve, and on the Left is Extrusion...
Thu, Dec 11, 2008 at 7:29:10 AM | Coffee Mug
Thread Post Kudo! #5
rossaftermath
5 Stars: 5 Votes
Thanks guys..
I came up with a solution to the problem.. its not the best solution tho..
I just radial arrayed the revolve from a center point about 8 times
It seemed to have worked.. but i guess the more times it goes over its self the more accurate it will be..
the handle still needs work.. i just need to fix up the sweep
However its not a good idea if you plan to export it from revit..
I like coffee
Thu, Dec 11, 2008 at 8:18:44 AM | Coffee Mug
KingRevit
4 Stars: 12 Votes
this issue has been logged to autodesk and they said they are working on it for the next release to get more acuracy on small curved objects particuallry revolves. i wouldn't worry about coffee cups but it is a big problem with hand rails
Fri, Dec 12, 2008 at 2:53:49 AM | Coffee Mug
rossaftermath
5 Stars: 5 Votes
Hmm.. never noticed it with hand rails, I thought because they were profile-based sweep they wouldn't have the issue, where do the facets occur?(balsters,rails?)
I have another question.. why is it when ever i export files to dwg, spherical objects always come out malformed?
coffee machine
Tue, Sep 1, 2009 at 10:36:50 AM
Need a Coffee Station
Wed, Sep 15, 2010 at 7:26:59 PM
copy in family killing parameters.
Wed, Oct 17, 2012 at 8:23:53 AM
New Project (Need suggestion/design)
Thu, Sep 6, 2012 at 12:52:08 PM
Favorite Snack while Revit-ing
Mon, Aug 31, 2009 at 6:11:47 PM
Page generation time: 0.3407
