58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> importing topos for a Site Plan
Mon, May 23, 2005 at 3:12:37 PM | importing topos for a Site Plan
rgaaia
I have tried numerous times to import an Autocad site survey and use it as my existing site survey on a REVIT 7.0 project. The topo lines are three-dimensional. It seems to import OK and is visible but when I request to use the imported file as my topo, it won't let me pick the survey. I have gone through the routine several times to see if settings are appropriate and have tried many combinations. Any help on tricks to do this so I don't have to re-create the entire survey.
Mon, May 23, 2005 at 8:52:54 PM | RE: importing topos for a Site Plan
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When importing the site survey make sure Current view only is not ticked. otherwise when imported it will come in as 2D. HTH.
Fri, May 27, 2005 at 9:43:13 AM | RE: importing topos for a Site Plan
rgaaia
thanks but I have done that.............I know this should work..........any other ideas???
Sat, May 28, 2005 at 10:20:14 PM | RE: importing topos for a Site Plan
eldados
eldados Avatar
4.5 Stars: 8 Votes
is your survey plan made of closed poly lines? if not you won't be able to create topo out of it...
Importing site plan to do a 3D topography
Sun, Jan 29, 2006 at 11:53:51 PM
DWG Site plan not importing correctly..
Wed, Apr 1, 2009 at 4:43:32 PM
Site TOPOs
Thu, Jun 14, 2007 at 12:02:25 PM
site plan disappears intermittently
Thu, Mar 16, 2017 at 9:21:13 PM
Cadd architectural site plan mystery
Wed, Jul 16, 2008 at 2:28:52 PM
Page generation time: 1.1516
