74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Everything but Annotations print off halftone HELP!
Tue, Dec 9, 2008 at 1:09:36 PM | Everything but Annotations print off halftone HELP!
lrcarr048
I am a student new to Revit. I have a big project do today. I printed my drawing yesterday and it was fine now everything but Annotations, Titleblock, schedules is printing in sceened half tone. If anyone can help Thanks
Larry
Tue, Dec 9, 2008 at 1:21:55 PM | Everything but Annotations print off halftone HELP!
lrcarr048
I think it has to do with design options I do not know
Tue, Dec 9, 2008 at 2:02:20 PM | Everything but Annotations print off halftone HELP!
Did you print from a sheet where you had the view activated?  That will cause the view window to be screened.
You should not be printing from an design option.  Control what DO prints through your VG settings.
Tue, Dec 9, 2008 at 3:22:41 PM | Everything but Annotations print off halftone HELP!
lrcarr048
Iam not sure what i have. I was looking at the design option not knowing what they are and now when I select a design option button everything but annotations turns grey in every view. It prints that way too. I have tryed every one and the only thing I can select is the annotations. I will attach a pdf of one of the sheets maybe that will help. The one named sweeper is the way it used to be. 2ndphase2 is the greyed out one.
Thank you for all your help. I can not tell you guys/gals how many times you have saved my butt. I know that if I have a question all I have to do is go to RevitCity.
Tue, Dec 9, 2008 at 3:40:08 PM | Everything but Annotations print off halftone HELP!
When you are in a design option edit mode, only the model elements that exist in that design option will be solid.  Everthing else will be ghosted.  As I said, don't print from here.  You have to exit the DO edit mode. Get to the design option edit window and finish editing.  Now, everything should be black.
Did you add any modei elements while in a design option?
Tue, Dec 9, 2008 at 4:01:58 PM | Everything but Annotations print off halftone HELP!
lrcarr048
I don't think so. When I get out of edit mode. evry thing turns black again. It still prints grey. I looked to see where i can change the VG all I found was the design options tab with the selection for auto or a sub option. Maybe Im missing it. I have them set to auto like the other threads tell you to. Is there another option somewhere.
Thanks
Larry
Tue, Dec 9, 2008 at 4:05:20 PM | Everything but Annotations print off halftone HELP!
tim123
4 Stars: 19 Votes
Did you try the previous suggestion and deactivate the viewport?
Tue, Dec 9, 2008 at 4:14:19 PM | Everything but Annotations print off halftone HELP!
I looked at your pdf's - nothing appears to be ghosted.  PDF's are typically strange if anything is skewed off x/y axis.  Print it and it will probably look ok.
Tue, Dec 9, 2008 at 4:14:27 PM | Everything but Annotations print off halftone HELP!
lrcarr048
Yes all view ports are deactivated. It looks right on my screen. It just prints wrong.
Tue, Dec 9, 2008 at 4:18:33 PM | Everything but Annotations print off halftone HELP!
lrcarr048
OK so Im freaking out for nothing. Thanks guys that worked I guess I was over thinking it. My professor rides us about using paper without reason. You guys/gals are great
Till next time
 Larry
Does not print anything but annotations
Thu, Oct 20, 2016 at 4:46:33 PM
Design Options Halftone?
Tue, Nov 20, 2018 at 10:58:56 PM
electrical plans
Sat, Feb 11, 2006 at 12:20:14 PM
Halftone setting in Visibilty Graphics
Thu, Sep 29, 2011 at 9:48:08 AM
Revit MEP 2012 - Halftone not Working...
Fri, Oct 5, 2012 at 12:47:21 PM
Page generation time: 0.6930
