92 Users Online (91 Members):
Forums >> Revit Building >> Technical Support >> Model Lines: Lineweight
The default for Model Lines (Thin) looks to be about a 3 or 4. However, I need them to be at a 1-2. When I have gone to the >Settings>Line Styles, I can only change to lineweight of the Detail Lines. How do I change the lineweight for the model lines?
In the view ... VG
But doesn't this only change it in view-specific? I'm looking for a more universal setting.
When you create the model line you can choose the line type.
The problem is that the model line types are thicker than model lines. It's great when working in the modeling process. But when you want to use a model line with a thickness of 1, it is still thicker than a detail line of a thickness of 1.
In the family go to object styles - the line settings are here.
Component - Model in place - Lineweight |
Fri, Feb 10, 2012 at 6:43:03 AM
symbolic lines |
Thu, Jul 13, 2006 at 8:15:41 PM
sketchy lines lineweight |
Mon, Jun 9, 2014 at 2:10:11 PM
Changing Lineweight of Crop Regions |
Mon, Jun 19, 2017 at 8:39:07 AM
Lineweight Tool Overlap |
Thu, Aug 7, 2008 at 9:25:16 AM
Members: | 2057421 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
