34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> several questions
Tue, Dec 9, 2008 at 11:02:13 AM | several questions
skyscraper
hey all
I accidentally posted this in the systems technical support section. it belongs here.
am working on a 3-story medical center building, will be our first revit project (yay!)
but I am having a few problems that I can't seem to figure out:
1. the west elevation view is not showing up at all. I click on the elevation camera, and the floor level markers show up but the building view does not. the camera is placed correctly. any ideas?
2. when I click on the "ground floor" plan view, I get what looks to be items that are on the "site" plan view. the ground floor items appear dashed. when I click on the "site" plan view, I get all of the items that are supposed to be on the ground floor. I queried an interior partition wall, and the properties indicate that it is placed on the ground floor but it is only showing as a dashed line in that view. ??
3. how do I prevent interior partitions from showing up dashed in other floor plan views?
thanks.
Tue, Dec 9, 2008 at 11:25:06 AM | several questions
tim123
4 Stars: 19 Votes
1: Your far clip is probably not allowing you to see this.  Go to View Properties and check your far clip distance.
2:Have you set these items  in the demolish phase?
Tue, Dec 9, 2008 at 11:44:54 AM | several questions
skyscraper
1. I just created a new west elevation, and it works fine. it doesn't solve the problem, but it is a work-around.
2. the elements are not in demolish phase; all are in new construction.
Tue, Dec 9, 2008 at 12:26:26 PM | several questions
If you click on an elevation marker in plan, the scope of yor view is shown with colored lines - soild shows the width and a dashed area shows the depth.  You can grap the grips and change this in the plan view.  Same for sections.
Please state Revit version being used in your questions [ 1 2 ]
Thu, Dec 15, 2016 at 6:32:17 AM
21
noob with questions and some experience
Sun, Oct 4, 2009 at 5:21:38 AM
Basic Questions
Wed, Dec 16, 2009 at 1:01:10 AM
PME questions and is this the proper forum for PME questions?
Wed, Mar 11, 2009 at 3:28:33 PM
Multiple Newbie Questions
Mon, Sep 23, 2013 at 8:47:23 AM
Page generation time: 0.2604
