33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window family
Tue, Dec 9, 2008 at 4:42:37 AM | Window family
Dafpfy
3.5 Stars: 11 Votes
Hi,
I have a window family that shows good in the family editor but when i place it in a project the glas seems to not do what it should anymore, the two windows are identical in parameters,
even worse, the window in the family editor is  the window from the project ( that was working ok ) that i did the edit family on, changed a parameter to an instance and reloaded it back in the project,  and it messed up.
any ideas on how this could be solved?
using rac 2008
Kind regards,
D
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Dec 9, 2008 at 4:51:23 AM | Window family
4 Stars: 203 Votes
Hi, edit the family and check if the "Glass" is attached (locked) to the frame...
Tue, Dec 9, 2008 at 4:56:02 AM | Window family
Dafpfy
3.5 Stars: 11 Votes
Those windows are nested components and change dimensions fine when i change them in there family editor :s
peace is the path."
Mahatma Gandhi.
Tue, Dec 9, 2008 at 6:04:46 AM | Window family
Dafpfy
3.5 Stars: 11 Votes
Noooooo,  the humanity!!
peace is the path."
Mahatma Gandhi.
Tue, Dec 9, 2008 at 10:12:14 AM | Window family
Dafpfy
3.5 Stars: 11 Votes
i got it fixed but dont ask me what the problem was, i mostly just used edit family / edit family and then load into family and load into project without changing much and now everything seems fine for now,
peace is the path."
Mahatma Gandhi.
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:30 AM
Imported family not flexing in window family
Thu, Jan 31, 2013 at 7:21:53 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
having trouble with window rfa
Mon, Sep 8, 2008 at 10:37:11 AM
basic window family tutorial(step by step)
Mon, Sep 6, 2010 at 7:26:53 PM
Page generation time: 1.2807
