52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exterior accent colors
Mon, Dec 8, 2008 at 5:38:05 PM | Exterior accent colors
elduderino1234
The image I attached is a rendering that my office put together. What I am trying to do (and have struggled with) is re-create the yellow accent band, the gray accent band at the top corner of the foreground part of the building, and the gray accent band between the windows. What I have tried to do so far is create a window family with the lower window and then a different colored solid mass above it. After insterting the window family to the revit model, I tried to join the walls but it did not work. I also tried to use a wall sweep which also did not work. Can anybody please help me out? Thanks
Tue, Dec 9, 2008 at 8:38:29 AM | Exterior accent colors
tim123
4 Stars: 19 Votes
You can create these as part of your curtain wall, with different panel types for the different materials.  Define each with the required material.
Tue, Dec 9, 2008 at 9:28:43 AM | Exterior accent colors
3.5 Stars: 395 Votes
I would model it like it is.... a curtain wall above and below a solid wall (EIFS?) that has a different finish than the main solid walls.  Could be the same wall type but with a "poured" on finish.
Accent panel that cuts through 2 walls
Wed, Dec 3, 2008 at 6:46:02 PM
Exterior walls
Sat, Jun 16, 2007 at 10:59:39 AM
Similar wall types with different finish colors...
Thu, Apr 17, 2014 at 1:00:57 PM
Colors and Patterns in Revit 2013
Fri, May 25, 2012 at 7:54:54 PM
Colors and Printing
Thu, Jul 19, 2012 at 10:11:31 AM
Page generation time: 0.3156
