110 Users Online (108 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> surface pattern visibility
Mon, Dec 8, 2008 at 3:45:37 PM | surface pattern visibility
dfitzladdy
5 Stars: 3 Votes
I have a surface pattern that's showing up in certain parts of my elevation, and in others it's not.
They are not walls, they blocks i created that have a uniform material (concrete), so there's not the issue of the wall being inside out.
Not sure what it's about.... anyone have any ideas?
See attached image of example
Mon, Dec 8, 2008 at 4:14:15 PM | surface pattern visibility
Manny
3.5 Stars: 6 Votes
check you base constraint, or your floor cut pattern
Fri, Sep 13, 2013 at 9:46:30 AM
surface pattern visibility issues
Thu, Jan 5, 2006 at 3:13:48 PM
Surface pattern
Mon, Sep 10, 2007 at 11:18:02 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:34 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:01 PM
Page generation time: 0.5212
