69 Users Online (68 Members):
Forums >> Workflow & Implementation >> Hardware >> Revit 32 bit vs 64 bit on laptop
![3 Stars: 1 Votes](/images/stars_3.gif) |
I have a new desktop coming with the Newhalem quad core and 12 GB RAM. No problem here as I will have Vista 64 Business installed.The question is my Dell M90 laptop with 4 GB RAM. I have Revit 32 on it with Windows XP Pro. Is there an advantage to installing Vista 64 Business and Revit 64 on the M90? I'm not sure if any upgrades to the M90 are possible, or how expensive, but that could be a possiblity.Also, I will be transfering everything to the new computer from my old desktop and plan to use the old one for my Wacom cintiq to work in Photoshop and Painter, but Revit 32 will still be there. My guess is that I can only have Revit on two machines per the license agreement. Is that true and does that installation of Revit become null after I authorize Revit 64 on the new machine?It seems from other threads and Wes' treatise on the subject that Revit files produced on both versions should be compatible. Comments please!!
----------------------------------- Thomas W. Hillis, LEED AP |
![3 Stars: 3 Votes](/images/stars_3.gif) |
I would personally upgrade to a 64bit operating system for the main reason that it understands what 4gig memory is. You will also see a difference in using revit 64bit vs the 32 bit. If you only have one revit license you are only allowed to have it on two machines. one being a work machince and one a home use. That is what is allowed with autodesk elua.
windows XP Professional x 64 bit |
Wed, Sep 27, 2006 at 12:39:51 PM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ] |
Sat, Apr 4, 2009 at 1:38:57 AM
29
Thinking about switching to 64 bit Revit. Got questions. |
Mon, Jun 8, 2009 at 2:48:16 PM
Got questions about moving to 64 bit |
Wed, Jun 10, 2009 at 11:05:38 AM
64 bit version |
Wed, Nov 5, 2008 at 11:26:19 AM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
