46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stacked walls and regular walls won't clean joins
Mon, May 23, 2005 at 1:58:11 PM | Stacked walls and regular walls won't clean joins
joyd
When I use a stacked wall for an exterior wall they won't clean the joins to interior walls. I checked all my finish types are the same and don't have any wrapping going on. Is there something else I'm missing?
Mon, May 23, 2005 at 8:42:41 PM | RE: Stacked walls and regular walls won't clean joins
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make sure you are using the latest build. If you are still having problems post a screenshot and/or example file with the wall types.
wall joins at stacked wall not clean
Mon, Nov 15, 2010 at 11:57:34 AM
stacked wall troubles
Tue, Feb 13, 2007 at 2:47:36 PM
Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 1:19:19 PM
Stacked wall joins, floor cut geometry, etc..
Wed, Sep 2, 2009 at 3:21:22 PM
Dimension Stacked Walls
Thu, Aug 18, 2011 at 12:23:35 PM
Page generation time: 1.2547
