59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Worksets >> Worksets
Mon, May 23, 2005 at 1:49:34 PM | Worksets
jeffcramer-edcarc
I have enabled worksets on a project. I would like to disable worksets for this drawing. How can I disable worksets for a revit drawing.
Mon, May 23, 2005 at 2:02:24 PM | RE: Worksets
TomDorner
4.5 Stars: 25 Votes
I don't believe there is a way. Once worksets are enabled, they are there for the duration. I'm not sure you can even cut and paste the entities to a new non-workseted project, but that would be the only way I could think of. You can always merge worksets together to get a more simplified workset structure. We do this many times by having two worksets "grids, levels" and "everything else". HTH Tom
Mon, May 23, 2005 at 8:51:22 PM | RE: Worksets
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Tom is correct. Once worksets are enabled there is no way to turn them off. This is noted when you first turn them on with a warning message in revit. We often have a period where there might be only one person working on a project after worksets are enabled its just a matter of going to your worksets showing everything selecting all and making editable.
Mon, May 23, 2005 at 9:25:16 PM | RE: Worksets
DTS
You can't disable worksets... but enabling it does have it's perks; you will have an extra benefit of additional backup files on a different computer. The central project can be store on the network (seperate comp) somewhere and a local file on your own PC. In case one machine screws up... as long as u've saved regularly to central.
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Wed, Feb 1, 2012 at 5:04:15 PM
Worksets question - standards question...
Wed, Oct 21, 2009 at 7:28:40 AM
Tue, Oct 23, 2007 at 2:36:13 PM
Page generation time: 0.2487
