Forums >> Revit Building >> Technical Support >> Titleblocks & Design Options
59 Posts No Rating |
Is there a way to associate titleblocks with design options? I have several design options that create several of the same sheet - in a perfect world those additional sheets would go away with everything else once that design option has been selected.....thoughts?
----------------------------------- Bradley |
Your post is not very clear.... You can control design options through your view VG. So you can activate the view, turn on DO #1 and print, activate the view again and do the same for DO#2 ...etc. You could also create multiple sheets with copies of the same view but with the correct DO set. Each sheet would have to have a different identity ... but I would think you would want that anyway.
as far as i know there is no way to create a relationship between a Design Option and a sheet.
I have the views set up with the correct DO - that's obvious. What i want is for the sheet to go away along with the 'unwanted' views - that way my sheet index will automatically update itself too. I know i can set my sheet index to correspond with the different DO's, I just think it would be easier to remove the old sheets with the DO.....
Levels & Design Options |
Tue, Jul 25, 2006 at 8:24:12 AM
Design options issues |
Thu, Mar 2, 2006 at 10:35:32 AM
Design Options |
Wed, Dec 24, 2003 at 10:33:52 AM
design options tied to other objects (version 2008) |
Tue, Apr 1, 2008 at 6:17:37 AM
Text In Design Options |
Fri, May 28, 2010 at 3:25:08 PM
Members: | 2098571 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
