130 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Railings
Sun, May 22, 2005 at 8:22:43 AM | Railings
witsend
Hello I am having difficulty drawing a railing that runs at an incline to the horizontal. Can anybody help ? So far I have tried: Setting the work plane to the required angle and then drawing the railing but Revit wont allow me to draw a railing in any view when I have the work plane set at an angle. Drawing the railing on a host ramp then moving it - but it just pops back to the horizontal plane. And everything else I can think of. I am running Revit 7 and I am a beginner. Thank you witsend
Sun, May 22, 2005 at 1:37:20 PM | RE: Railings
Xane
When You select the railing with 'set host' pick on ramp, it should be fix it.
Sun, May 22, 2005 at 8:57:36 PM | RE: Railings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
As mentioned by Xane use the pick host option on a floor, ramp or stair is the best bet. Make sure the sketch doesn't extend beyond the extents of the element though or it will revert back to horizontal. It can extend beyond but you must break the line at the end of the element and begin a new line. HTH.
Tue, May 24, 2005 at 6:03:18 AM | RE: Railings
witsend
Thank you for your help. The problem is however that I am trying to draw the railings along the top of a wall not a staircase or ramp. Is this posible ? Any further ideas much appreciated
Tue, May 24, 2005 at 8:44:16 PM | RE: Railings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No you cannot set wall as the host. You could embed a small floor or ramp into the wall and use that as the host though. HTH.
RAILINGS RAILINGS?????
Wed, Oct 1, 2008 at 3:48:49 PM
Frenc h railings
Wed, Feb 18, 2009 at 2:51:56 PM
11
Problems attaching railings to stairs
Mon, Dec 2, 2013 at 10:49:14 AM
stair railings-inserting glass
Mon, Dec 9, 2013 at 11:37:40 AM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Page generation time: 1.6006
