Forums >> Revit Building >> Technical Support >> Errors when importing sketchup model into mass
Hi Folks, I'm wondering if anyone can shed some light on something for me. I'm trying to import a sketchup model into Revit 2009. I create a new mass, but when I try to import the skp file, it just says 'can't open c:/house.skp' Has anyone come across this problem before or has any suggestions? thanks, Gareth
No, what i do with Sketchup models is First Export 3D to DWG then in REVIT import DWG...
I'm afraid I don't have sketchup pro, so i can't export to dwg
10 Posts No Rating |
Hey Typoon...when you export the skp model to dwg, are we then able to assign properties to the elements? i.e., walls are concrete, roof is wood?
What i do is assign colors to the elements then when i import to Revit i go to materials and change those colors to the materials i want...
Cool bro. Thanks for the info.
problems importing sketchup |
Thu, Nov 24, 2011 at 4:10:20 AM
Wall Roof Join Error with Sketchup Mass |
Wed, Jun 24, 2009 at 4:28:01 PM
Sketchup model becoming an adaptive component |
Tue, May 21, 2013 at 8:02:12 AM
Importing Sketchup into Revit |
Fri, Nov 5, 2010 at 10:57:41 AM
12
Manipulating sketchup objects in Revit |
Tue, Jul 17, 2007 at 9:24:34 AM
11
Members: | 2101388 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
