39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Create parameter that can be 0"
Thu, Dec 4, 2008 at 7:40:45 PM | Create parameter that can be 0"
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is there a way to create a dimension label to 0".  When I have a family and let's say I have that parameter by default to 1".  But the user changes the parameter to 0" in a specific project.  It always can't create the family and deletes it.  Is there a way to creat this?  Thanks.
Lorne
Denver, CO
Revit Architecture
Fri, Dec 5, 2008 at 12:23:38 PM | Create parameter that can be 0"
dano3d
3.5 Stars: 3 Votes
Hi lorne17.
Attached is a simple family that shows what I've been doing to allow for a dimension of zero. The basic idea is to make the object longer than the "length" paramerer and use a void mass to "hide" the extra length. I think the issue that causes Revit to blow-up an object when you try to enter a zero dimension is that it still needs part of the object to exist, even if that object is "hidden".
Dan3d
Fri, Dec 5, 2008 at 12:57:26 PM | Create parameter that can be 0"
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Dano,
Yea thanks for that.  Another way I found was to use two dimensions.  See attached.  I used this to move the obect to 0" of the reference.  I was making a bathroom mirror and need to be able to recess the mirror into the wall 1/4" because we wanted it flush with the tile.  But in other instances we want it on the face of the wall.  So I wanted the parameter of "Recessed Depth" to be at 0" or 1/4" or whatever.  This is the method I used to move it.  Just thought it would be helpful.
Thanks,
Lorne
Edited on: Fri, Dec 5, 2008 at 12:58:05 PM
Denver, CO
Revit Architecture
Thu, Mar 10, 2011 at 1:03:28 PM | Create parameter that can be 0"
ricedesign
Not sure if its too late to reply, but what I have used is a double reference plane. The bottom of "Unit 1" and the Top of "Unit 2".  Then I dimension the distance add a parameter and set it to "0". I dont think I have had the problem of objects disappearing...maybe its been fixed though since this question was posted, I am using Revit2010.
Thu, Mar 10, 2011 at 2:24:24 PM | Create parameter that can be 0"
I have not run into this problem but I can understand it.  You can't have an extrusion of 0.  But instead of cutting something off the better answer would be as follows: (Formulas not Revit correct)
  1. Set the visibilty of the item to: If (Extrusion length>0, Show it, Don't show it)
  2. Set the modeled extrusion length to: If(Extrusion>0,Extrusion,1)
This extrusion would always be at least 1 but might not be shown.
Sun, Oct 9, 2022 at 7:49:21 AM | Create parameter that can be 0"
denisquemore
Thank you guys so much. Feel myself a genius rn
"Group parameter under:"
Wed, Aug 22, 2018 at 10:42:29 AM
11
"group parameter under" changed upon loading into project
Wed, Aug 11, 2021 at 3:16:04 PM
I can't see "Height" parameter value of Wall or Currtain Wall Schedule?
Thu, Apr 27, 2017 at 2:04:40 AM
Edit Color Scheme: "Color" parameter
Wed, Feb 23, 2011 at 10:12:01 AM
Changing the value of a Length parameter based on the value of a Yes/No paramete
Fri, Apr 10, 2009 at 11:37:51 AM
Page generation time: 1.3448
