39 Users Online (37 Members):
Forums >> Revit Structure >> Technical Support >> How to match .CTB line weights with Revit
5 Posts No Rating |
When I want to change the line weights of a linked DWG file from REVIT, I link it in black and white and then "Import Line Weights DWG/DXF" to change the line weight of the colors I need to be darker or lighter. This might not be the best way to reach the desired effect, but it works very quickly. My question is how can I cross ref. a line weight from a CTB file so that I can make the exact same thickness in Revit? In a CTB file, the line weights are in millimeters or inches. What are Revit line weights in? Example: .05mm line weight in AutoCAD = ? line weight in REVIT
5 Posts No Rating |
Alright, I figured that out. Rivet shows the line wiegth in inches under the settings. All I had to do was cross ref the mm width of AutoCAD to the closest number (1-16 = .00#"-.#" in Revit and it works really well. But now I am not able to change the thickness of any of the text from the linked dwg file (no matter what color it is). Anyone know why?
Line weights & detailing 2012 |
Thu, Jun 6, 2013 at 7:51:24 PM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
A Nice set of Revit Line Weights |
Wed, Jun 20, 2007 at 8:47:36 PM
Revit line weights |
Wed, May 15, 2013 at 10:49:44 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
