50 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Seeing walls and floor through and elevation
10 Posts No Rating |
Hi I have an elevation set up of a building i am working on and the I can see the walls and floors though the wall. Only trhe object touching the wall are showing through. I have hidden line on in the view so I would not see throuh the wall. all the other elevations are fine. I have tried recreating the elevation view but the same occurs. I need to get this out today does anyone have any suggestion as to what I can do? Any help would be apreciated
45 Posts No Rating |
Can you post the file?
I dont understand the cause of the problem, but you could hide in view category and objects that are showing trough the elevation. Math.
Thanks for the help I am not sure how or what was chenged in graphics override but when i went to another elevation i made a view template from the working view and applied it to the tweaky elevation. It worked. Thank you for your help C
2nd flr walls not lining up with first floor walls |
Wed, Jun 16, 2010 at 2:20:42 PM
Interior elevation tag not cropping to floor/ceiling/walls |
Wed, Aug 18, 2010 at 9:31:49 AM
floor and wall joining and finish material |
Fri, Oct 25, 2013 at 1:35:18 PM
Curtaing walls in Legends???? |
Thu, Feb 25, 2010 at 2:27:32 PM
Cut floor around walls |
Fri, May 24, 2013 at 12:09:36 PM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
