50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walls are see through and i can see items in wireframe inside building
Thu, Dec 4, 2008 at 11:23:26 AM | Walls are see through and i can see items in wireframe inside building
Orty
So heres the problem and i'll try to explain it as best i can.  When i'm in 3D view and i'm looking at my house the walls are there and show some of there mass, but i can also see through them and see items in the house.  I can see all of my interior items such as tiolets,refrigerators etc in wire frame.  I really dont know were to look.  Mind you i'm fairly new to revit, but i've had multiple other people look at it for the basic stuff it might be(shading,mass etc) and its not anything that they could find.  I have a feeling that its one of those problems that the answer is right in front of me, but i'm not seeing it.  Help!!!
Thu, Dec 4, 2008 at 12:06:03 PM | Walls are see through and i can see items in wireframe inside building
4 Stars: 203 Votes
Hi, if this is what i think it's very easy, you are in 3D view in shade mode and you can see through the walls??? that's it??? OK, if this is what's happend, delete this 3D view and create a new one, that solve the problem for now, this issue are answer here i think 100 times, there are some problems with revit and graphics card i guess, Can you tell me please, What Graphic card do you use???
Arch Walls Block View of Struct Posts
Tue, Feb 11, 2014 at 2:16:48 PM
Temporary wireframe
Thu, Aug 26, 2010 at 12:14:57 PM
Walls with 2" airs space on inside, whole wall is transparent form insed view?
Wed, Mar 12, 2014 at 3:45:23 PM
Make demolition walls wireframe
Wed, Oct 26, 2016 at 2:22:21 PM
Elevations showing items behind walls
Wed, Aug 30, 2017 at 10:58:45 AM
Page generation time: 2.4629
