65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Precast panels and vertical reveals
Wed, Dec 3, 2008 at 6:23:48 PM | Precast panels and vertical reveals
sweetiedarling
Hi - We're thinking through the various ways to model tilt-up precast panels. The panels will have horizontal reveals, and vertical reveals within the panel and at the edges. We play a lot with reveal patterns, and mixing panel types so flexibility and changes are key. I haven't yet hit on a really good solution to manage the vertical reveals.... But I've thought through a couple of different ways, and would appreciate any suggestions on how other folks are modeling.
1 - Curtainwall - Populate the grid with a wall family defined with the horizontal reveals. Vertical reveals seem to be more of an issue here, as they need to be placed individually on each panel, and if the grid changes from say 8' to 6' all the reveals need to be moved or recreated. The array command doesn't seem to work across the panels. Anyone know a way to make a mullion act like a void reveal???
2 - Basic Wall - this seems to be an ok solution if all the panels for a good extent of the elevation have the same horizontal reveal. Vertical reveals can be arrayed to fake the joint between the panel, and the vertical reveal at the edge of the panel. Arrays seem a little fussy to edit, but at least allow a quick change in joint spacing. However, once a couple of types of panels are in the mix, this seems like it could be cumbersome.
3 - Create a model group for each panel type - Conceptually this seems to resonate with the way we think about the panel layout - each panel is an object, change one of a type and they all change. The exterior wall is then a series of walls. The downside - if the width of the panel changes, one has to shuffle around the panels.
Thanks!
Wed, Dec 3, 2008 at 6:56:01 PM | Precast panels and vertical reveals
I responded to a question about this a few months ago. http://www.revitcity.com/forums.php?action=viewthread&thread_id=12741
Thu, Dec 4, 2008 at 9:11:23 AM | Precast panels and vertical reveals
sweetiedarling
thanks! there are always so many different ways to accomplish the same task... nice to know how other folks are doing it.
Wed, Jan 16, 2013 at 1:18:04 AM | Precast panels and vertical reveals
murtuza
hi
please help me how you can make the grove in precast panels at parapet copping
Wed, Jan 16, 2013 at 7:11:38 AM | Precast panels and vertical reveals
Wall reveal.  Read your HELP if you don't know how.
Wed, Jan 16, 2013 at 7:30:32 AM | Precast panels and vertical reveals
murtuza
THANKS FOR YOUR QUICK REPLY HERE IS MY ATTACHED FILE FOR REVIT
     I M WORKING IN PRECAST COMPANY WHICH IS DEALING WITH PRECAST PANELS THIS IS PARAPET PIECE THE PROBLEM IS REVEAL (FALSE JOINT) IS NOT PASSING THROW PARAPET
Wed, Jan 16, 2013 at 9:09:29 AM | Precast panels and vertical reveals
Look at my earlier post in 2008 - It shows what I think you want.  The sweep profile has to be larger than the wall to cut it all the way through.
Thu, Jan 17, 2013 at 3:31:00 AM | Precast panels and vertical reveals
murtuza
HI
BUT SWEEP WILL CUT ALL THE PRECAST PIECE BUT I WANT TO SHOW FALSE JOINT ONLY AS PER ATTACHED SKETCH BEFORE
Thu, Jan 17, 2013 at 9:38:53 AM | Precast panels and vertical reveals
Then do that!...Make the reveal not as deep.
Vertical chamfers on precast panels
Tue, Oct 25, 2011 at 4:31:50 PM
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:47 AM
Makeing Precast Panels
Mon, Aug 17, 2009 at 7:35:06 AM
Reveals - Face Based Family
Sat, Feb 25, 2012 at 7:37:31 AM
line weight on precast family w/ reveals
Fri, Jun 25, 2010 at 12:14:14 PM
Page generation time: 8.5875
