48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Accent panel that cuts through 2 walls
Wed, Dec 3, 2008 at 1:11:23 PM | Accent panel that cuts through 2 walls
elduderino1234
RAC 2008
 I am a relative RAC newbie. I used it awhile ago, but only for student projects. Now I am using it in an office environment which is totally different. What I am trying to do is create an exterior accent panel above a window that can cut through two walls (the one is it being placed on as well as the one above). The panel represents a material change. I made it as a Wall - Component but for some reason it will only cut through the one wall that it is placed on. Any suggestions?
Wed, Dec 3, 2008 at 2:03:55 PM | Accent panel that cuts through 2 walls
3.5 Stars: 395 Votes
Use join geometry ... should work.
Wed, Dec 3, 2008 at 6:46:02 PM | Accent panel that cuts through 2 walls
elduderino1234
So I click join geometry then click one wall and then the other? Because after selecting one wall, the other wall is not able to be selected.
Exterior accent colors
Tue, Dec 9, 2008 at 9:28:43 AM
Door that cuts a curtain and a normal wall at the same time
Sat, Jun 1, 2019 at 7:33:18 PM
Window family that cuts walls?
Tue, Sep 2, 2008 at 12:41:38 PM
panel walls - getting walls to subdivide automatically with joints already in.
Wed, Nov 24, 2010 at 6:22:27 PM
composite panel walls
Fri, Feb 25, 2011 at 1:32:37 PM
Page generation time: 8.3367
