61 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> Foundation walls in elevation
5 Posts No Rating |
I need to know how other people deal with foundation walls in elevation. What is the best way to have foundation walls show as dashed in elevation? I typically use phasing and make the foundation existing and demo them in construction phase. The problem I have with this method is when the wall is cut in section it shows as demolished wall and I have to use the line tool or fill pattern to manually fix.
Thanks in advance
Todd
17 Posts No Rating |
I use filled region, as solid white, and use the dashed lines for the border of the region that is underground & use the wide line for the grade.
Why demolish them...
Why not just change your existing filter to show a dashed line?
5 Posts No Rating |
Thanks for the responses. I guess I'm still having a problem though. I can not just turn existing phase to dashed because there is an existing building that needs to be shown. Maybe I'm missing something about what Mr Spot is trying to tell me. If there is an easy solution im not seeing it.
Thanks again
Todd
Refer here for a few different options. you'll need to signup with augi if you haven't already.
http://forums.augi.com/showthread.php?t=14495&highlight=foundation+walls
HTH.
Foundation Wall Issue |
Tue, Mar 23, 2010 at 4:59:46 PM
Foundation Walls not mitering? |
Fri, Jan 25, 2008 at 9:10:52 AM
Structural Foundation Tag with Elevation |
Tue, Mar 20, 2012 at 12:05:31 PM
line style in plan view |
Thu, Mar 4, 2004 at 12:47:43 PM
Elevation marks Top and Bottom |
Mon, Apr 20, 2015 at 4:57:40 PM
Members: | 2017481 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
