75 Users Online (72 Members):
Forums >> Community >> Newbies >> Question regarding Sweeps used in a wall Family
7 Posts No Rating |
Question from a Revit novice: I added a Sweep to a particualr wall Family that I had been previously using in the project. All the new walls that I create of this same type since then have the sweep (that's good). Unfortunately, all the old walls made prior to the sweep do not update to include the sweep (that's bad). Is there a setting or something that would allow new sweeps to behave retroactively in old walls of the same name/family?? I tried match properties, but that didn't work. Thanks
That is strange. It should have updated all the wall of the same family and type within the project. Check to make sure that the walls in question are the exact same wall type as the one you updated. Other than that I don't know why they are not updating. Have you checked both sides of the particular walls. I once added a sweep profile and didn't realize that all of my exterior walls were drawn with the exterior side facing the inside of the building.
Yeah, they must have different "Name" (family)....
7 Posts No Rating |
Thankyou JAMESHGRIMES & TYPHOON. It was the name - I thought it was exact (looked at it a 100 times) but there was a very subtle difference that made all the difference - worked perfectly.
Angling Wall Sweeps |
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:55 AM
wall sweeps |
Mon, Dec 29, 2008 at 5:20:42 PM
Wall Sweeps or In-Place Family Sweeps |
Wed, Sep 16, 2009 at 8:07:58 PM
Outlets and Wall Sweeps |
Wed, Feb 29, 2012 at 9:39:46 AM
Members: | 2017271 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
