122 Users Online (121 Members):
Forums >> Revit Building >> Technical Support >> keeping things proportional
2 Posts No Rating |
I am still kinda new to revit architecture and i need a little help. is there a way to change the dimensions of a building proportionally? lets say i have the walls of a building drawn and i need to change a dimensions proportionally, so if i have essentially drawn a box and the current walls are 8 by 8, is there a quick way to make it a 16 by 16 and have all the inner walls change proportionally as well? My builiding is alittle more complicated than a box but still, im hope there is a way to rescale walls in Revit Architecture.
Cross everything in the file and use the re-size tool just to the right of the mirror tool. Pick a reference point and then everything spatially can be re-sized proportionally in two directions. Family objects will not change size ...8" walls will remain 8" walls. etc.
Keeping Ref. Plans Parallel to Each Other |
Mon, Dec 14, 2015 at 3:04:15 PM
Changing Project Levels While Keeping Survey Point Levels |
Wed, Dec 4, 2013 at 3:49:12 PM
keeping text horizontal while rotating view 90 degrees. |
Thu, Aug 13, 2009 at 7:09:55 AM
Elevations and plans all messed up |
Mon, Dec 16, 2013 at 1:50:42 PM
Things getting Deleted! |
Thu, Apr 2, 2009 at 11:57:11 AM
Members: | 2057757 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
