Forums >> Revit Building >> Technical Support >> Where is the Line Patttern info stored.
83 Posts No Rating |
Hi Rather than type in all the line data in I was thinking I could reformat my old acad.lin to suit revit. I looked in the Registry but couldn't find it. Is it stored within each rvt/rte file? Is seems strange that you can use Acad hatch pattern files, but not linetypes :-( Hope you can help Cheers Dave F.
read your help - line patterns... it tells all that there is.
i don't think line patterns are read from a file as in Autocad. they are just simple dots, dashes, and spaces only. ???? HTH
WWHub I did read the help file, but as we all know about the Revit documentation, it rarely tells the whole story & leaves a lot to be desired. Cheers Dave F.
Well, in this case, REVIT HELP tells you that the linetypes are stored with the project file and then it goes on to tell you how to make them... I don't believe it is any clearer than that and it does tell you all. Please learn to use REVIT's help .... it is not like AutoCAD. It is much more complete and is really a help!
Are line patterns stored in a family? |
Fri, Sep 3, 2010 at 6:12:54 PM
Where in Revit 2015 are Patterns stored? |
Fri, Jan 8, 2016 at 1:26:00 PM
Nested families stored in project - Not in family |
Mon, Jun 20, 2011 at 4:21:13 PM
patttern downloads |
Thu, Jun 22, 2006 at 9:48:15 AM
Ground Floor info. appearing on Second Floor |
Thu, Jun 9, 2016 at 2:24:41 PM
Members: | 2100572 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
