71 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> topo goes through building
Sat, Nov 29, 2008 at 7:15:21 PM | topo goes through building
cljahnke
I have a building that is split level-sitting on a slope...when i add my topograpy with the points...it goes through my building in the 3d views. Is there a way to make the topography stop at the building edges?
Sat, Nov 29, 2008 at 9:35:04 PM | topo goes through building
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Ok cljahnke, if I understand well your doubt, you want to "cut" the terrain that goes through your building. Click Site menu-Pad, or on the Site tab of the Design Bar click Pad, then with lines, sketch the contour of your building, click finish sketch, so it will cut the terrain exactly around your building, hope it could help you.
Sat, Nov 29, 2008 at 11:58:28 PM | topo goes through building
cljahnke
Yep! thanks so much! that worked perfectly. I feel silly that I didn't understand that before.
Modify Topo & Building together
Fri, Jul 13, 2012 at 9:14:10 AM
Topo is struggling
Tue, Aug 15, 2006 at 9:24:02 AM
Elevation of Topo points
Tue, Nov 7, 2017 at 10:20:46 AM
Topo surface/Building Pad problems b/w Existing and New Construction phases
Sun, Feb 6, 2011 at 12:28:28 AM
Modeling Topo After Building
Fri, Jun 24, 2016 at 11:35:24 AM
Page generation time: 2.3156
